Why does my turn signal oonly work on one side?
Turn signal works normal on left side, but it blinks rapidly on right side and only the front light blinks.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi Dennis,
A rapidly blinking turn signal often means that the light bulb is about to burn out. Try replacing the bulbs and see if that fixes your problem. This video might help with the replacement: https://www.youtube.com/watch?v=c0Rk3kh2...
Good luck,
Paige
Bu yanıt yardımcı oldu mu?
You need a new Turn Signal Switch, relatively cheap part
Bulb replacement solved the problem
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 121
1 Yorum
Bulb replacement worked. Thank you
Dennis Johnson tarafından
