Ana içeriğe geç
Fahrenheit FHT 125PRMR saç düzleştirici, saçları iki seramik plaka arasında ısı kullanarak düzleştirir. Cihaz saçlarınızı düzleştirmek, kıvırmak veya dalgalı bir şekil vermek için kullanılabilir.
The temperature dial won't turn.
The temperature dial is stuck and does not turn. The temperature of the Fahrenheit FHT flatiron will not change when it is powered on. How do I get the dial to rotate so I can adjust the temperature?
Bu iyi bir soru mu?
Puan 0
1 Yorum
Always proof read your question before posting. Is it stick or stuck? What is Fahrenheit FHT? What is a Fahrenheit FHT 125PRMR?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello MeKenzie,
If the dial on the device is stuck this may be caused by a sticky substance building up around or under the dial. The first step would be to take a cleaning agent and anything that could fit under and around the edges of the dial and try to clean as much of the substances as you can. If it is still stuck then please refer to our troubleshooting page for a more technical solution.
www.ifixit.com/Wiki/Fahreheit_FHT_125PRMR_Troubleshooting
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hello,
If the dial is stuck it could be due to how it was the dial itself is seated. Please look at this troubleshooting page to find information on removal/replacement and proper seating of the dial.
Fahrenheit FHT 125PRMR Troubleshooting
Puan 0
Yorum Ekle
Yanıtını ekle
MeKenzie Hilsmeyer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 455
