Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
585 Soru Tümünü görüntüle
optical drive fan problem
I have a mid 2007 iMac EMC 2133. It all works fine except sometimes the optical drive fan runs at +4000rpm (checked using iStatPro). I ran the Apple Hardware Test and it showed this error:
4SNS/1/40000000:TOOP
I replaced the optical drive sensor cable and I have re-set the SMC and for a while I thought it brought the speed down, although it re-occurred later whilst running a few applications and then during the Apple HWT.
Haven't had much luck getting exact info on this (or any similar) error code.
Is this fixable? Or a serious issue please? Machine is out of warranty of course.
Thanks
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
That error code is listed as a hard drive sensor error. It may mean that the temp sensor on the hard drive needs to be replaced, or the logic board might be at fault. There's just nothing about anyone solving the problem. Personally I would suspect the actual sensor.
Here's a discussion on the problem at Apple.
http://discussions.apple.com/message.jsp...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
agreed +
tarafından
Yorum Ekle
Yanıtını ekle
pete sheckley sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 584
