Ana içeriğe geç
iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, iPhone X, iPhone XS ve iPhone XS Max orijinal ürünleri için nasıl-yapılır kılavuzları ve parça değişim kılavuzlarının tamamı.
36266 Soru Tümünü görüntüle
How can you repair the iPhone home button?
the button wont return home at all
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
1 Yorum
which iPhone?
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There is no soldering needed on this part! Home button flex connects to top of dock flex not the motherboard.
If button is still responsive but needs more pressure try following guide to open iPhone, disconnect ribbons1,2,3. Turn display over and you should see the 2 gold prongs beneath home button- use a small flathead screw driver to gently lift them up. Clean top of dock to get rid of dust etc. Reassemble. Gold prongs get flattened with use, they should be pointing upwards approx 45• to make contact with dock
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Try this first. Reposting from Ezekiel's solution that works!
Its a hardware issue that Apple overlooked. Try this work around to save money. Plug your iPhone USB cable into the phone (No need to plug the other end to anything) and grip the part right where it is plugged into the phone. Slightly bend it up towards the screen, just a little (You might even hear a click) and presto! This is guaranteed to work most of the time. If it doesn't, you need a new Home Button then.
Just dont blame anyone if you break something because this work around relies on your own strength..Ü
Puan 0
Yorum Ekle
try to calibrate your home button by doing this press power button until slide diplayed but do not turn off press home button where your finger point on exact position, try and try until you got your button function normal. good luck
Puan 0
Yorum Ekle
Bu cevap aslında başka bir soru için verilmişti.
Probably just needs a replacement home button flex, these can be found on ebay. Although if your unlucky the contact on the logic board may have come off, these are replaceable too but the soldering can be a tad fiddly.
Puan -1
Yorum Ekle
Yanıtını ekle
fitted2thamax sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 3,742
