Ana içeriğe geç
Loose-ish Home button after Front Panel Replacement
Hi,
I just replaced the front panel of an iphone 6 (space grey), and everything works fine, except for the home button being slightly loose. There is some wobble room and putting your finger on it you can feel the slight movement.
Is this a problem that can be solved by buying adhesive replacement?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
iPhone Pil Tamir Setleri
Only $29.99
Buy Now
Only $29.99
Buy Now
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you are referring to the home button gasket here then yes:
iPhone 6 and 6 Plus Home Button Gasket
iPhone 6 and 6 Plus Home Button Gasket Resmi
Ürün
$5,99
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
This can also be down to the fact that the glass isn't right. Copy screens use thin glass and sometimes have to add bits of plastic to make the home button sit right
Puan 2
Yorum Ekle
Trust the best thing to do is cute a piece of sticky tape ( the size of your home button) if your pro, stencil a circle shape and place it over your home button.. you’ll thank me later ;)
Puan 0
Yorum Ekle
Yanıtını ekle
mbarthet3 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 Gün: 55
Son 30 Gün: 292
Her zaman: 8,800
