Ana içeriğe geç
How to fix the seventh generation of Honda's compact car.
20 Soru Tümünü görüntüle
Horn 'button' does not work
How do I replace/fix the steering wheel activator system for the horn?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@leojik , Before pulling the steering wheel because your horn does not work, Check all fuses and horn relay and the horn itself. May be bad/corroded ground at the horn. Links below show horn fuse/relay locations, horn location and removal, steering wheel removal to access horns wiring/plug. Check the attached links,instruction and guides, Good luck.
http://troubleshootmyvehicle.com/honda/1...
https://www.youtube.com/watch?v=0ra0E0ph...
https://www.youtube.com/watch?v=d0GHgOCh...
Bu yanıt yardımcı oldu mu?
Puan 6
Yorum Ekle
I have put a live feed to the horn and it works but no live feed at the steering wheel and the srs air bag light is on
Puan 1
1 Yorum:
Through research for my own car, it appears that your issue is to do with something called the "coil spring". It's a device that allows the wires for the airbag, horn and other wheel controls to turn with the wheel without being damaged. Here's a YouTube video for you to take a look at: https://www.youtube.com/watch?v=3vFkSuoz...
tarafından
Yorum Ekle
Yanıtını ekle
Leo Klump sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 13,643
