Ana içeriğe geç
The Samsung Galaxy Tab E 9.6 Verizon, manufactured by Samsung Electronics America
25 Soru Tümünü görüntüle
Tablet went dead and won't turn on
My device doesn't power on when I press the power button, and doesn't seem to be responding to anything. I tried connecting it to a charger, but to no avail. What potential issues might've caused my device to stop turning on?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 17
8 Yorum
Tablet won't go on not even show
tarafından
I don’t know what is going on with my it won’t respond to nothin
tarafından
Mine vibrates like its coming on but then nothing and it dont have a sim card it's for my kid who only plays roblox and call of duty so no need for a sim card I wish I knew what was wrong , sorry I can't help
tarafından
it says my tablet is recovery booting what does that mean
tarafından
My samsung Galaxy Tab e is not turning on
tarafından
3 tane daha yorum göster
Yorum Ekle
10 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Try plugging it into power and then press and hold Volume Up, Home, and Power at the same time. After a few seconds the Samsung Logo should appear. If it does not then I would say either the battery has gone bad or the charge port has.
Bu yanıt yardımcı oldu mu?
Puan 8
5 Yorum:
Let me say it honestly~ It worked on it first try~ Thank you~
tarafından
Same here! Thanks!
tarafından
But, it wouldn’t accept any input and shut off again. I suspect a bad charge port. Looks like I need a new tablet.
tarafından
is it supposed to turn back off after?
tarafından
will this factory reset it? i hope not
tarafından
Yorum Ekle
Someone may have accidentally put tablet into safe mode or power off mode.. You may need to open the back up and remove the battery to allow any residual power to drain away. I left my battery out for 30 minutes as I was told. Seems one of the kids put tablet into power off mode meaning I couldn't turn it on.. At first I thought the battery was gone. But using a voltage reader it showed the battery was at a healthy 4.30V. Back to Google I went.. Then I found this idea and voila.,
Puan 3
1 Yorum:
THANK YOU SO MUCH! I tried your tip and saved my Galaxy Tab. I thought I might have to buy a new battery and doubted it would be worth it due to the tab's age. Now, we have a new device for our kids to use for online school for the rest of the pandemic/social distancing. I am so glad you have posted this tip! Many thanks!
tarafından
Yorum Ekle
Press the power button, and hold it for several seconds. If the device does not power on, it's possible the battery is faulty and won't hold a charge. Connect the device to a power source and wait for several minutes. If there is no indication the device is charging, try charging the device using a different micro-USB cable and adapter.
Puan 2
Yorum Ekle
My tab e was the same Volume Up did noting.
Had to open it up and disconnect the battery for 5 minutes not easy
working fine now
Puan 1
Yorum Ekle
I had the same problem with my tablet, I had to remove SD Card and Sim.. Then pressed and held both power and volume up buttons for 30 seconds.. The Samsung logo just appeared.
Puan 1
1 Yorum:
Yes after I have removed the memory card it works
tarafından
Yorum Ekle
Excelvan Q738 kids tablet…wouldn't turn on, but said fully charged while connected so I knew it wasn't a screen problem. Tried long pressing the power button…nothing. Then held power and volume up key until logo appeared..released the volume until reboot screen appeared …selected reboot and is now working fine
Puan 0
1 Yorum:
Scratch that. After removing the charger it went black and wouldn't turn back on. Connected charger...wouldn't turn back on without holding both power and volume up key. Did a device restore to factory settings...same thing.
tarafından
Yorum Ekle
I used suggestion for apple ipad even though mine is samsung. screen froze, audio worked, but could not leave app, or shut off. Then suddenly it went black on its own. I held down power and volume up buttons a bit, then it went on again. I went to settings and was informed that Tiktok app was eating away all my power, so had to be sure to shut off that app.
Puan 0
Yorum Ekle
you may need to boot safe mode
Turn the device off.
  1. Press and hold the Power key.
  2. When Samsung appears on the screen, release the Power key.
  3. Immediately after releasing the Power key, press and hold the Volume down key.
  4. Continue to hold the Volume down key until the device finishes restarting.
Puan 0
Yorum Ekle
Same thing happened to my galaxy tab 3. I fixed it by carefully removing the back cover (not for the faint of heart) and disconnecting the battery for a few minutes. The white battery connector has 6 wires going to it and lifts straight up and off 6 itty bitty pins. After a few minutes pop the battery connector back on. Don’t put the back cover back on yet. Plug the charger in and charge the tablet for 30 minutes. Then try turning the tablet on. It should turn on as usual. Carefully replace the back cover and make sure to snap the edges down all around. Fully charge the tablet. Don’t forget to re-enter your wifi passwords and reset the date and time or you won’t be able to access the web. Good luck.
Puan 0
Yorum Ekle
Where do I take my tablet because it won't turn on went it over heat, or do I have it fix my
Update (06/24/2021)
Can my tablet be fix I'm having problem with it
Puan 0
2 Yorum:
I'm over whelm because my tablet is not wanting to charge
tarafından
Diana Renteria what make and model is your tablet? What is going on with it and what have you tried?
tarafından
Yorum Ekle
Yanıtını ekle
Dave Dorzback sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 151
Son 30 gün: 561
Her zaman: 53,291
