Why won't my CD drive read CDs?
The laptop isn't reading the CD. I'm putting it in the CD drive, but the computer won't recognize that a CD has been inserted. Is this a problem with the laptop or the CD?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
While it is possible that the CD you are attempting to use is scratched or otherwise damaged, your laptop could also be the issue. Ensure that there is no dirt or other junk stuck in the CD drive that could possibly be causing it to malfunction. Additionally, try manually searching for the CD on your laptop my opening up your libraries, and navigating to the main drive. If you see the CD displayed here, then your laptop is recognizing the CD but is just not telling you. However, if it does not appear, and none of the other suggestions solved the issue, you may need to replace the CD drive itself.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 355
