My tablet can't pwer on
I have problem about huawei tablet
it's can't power on.
I checked the connector and the battery, no problem
what is the problem?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@mohamedeln , med, Found this info. from searching through forums with similar issue as your huawei tablet t1. Hard reset. Take your sim card and memory card from the tab before the reset, battery is fully charged. Personal data from the tab, contacts, pictures, messages, apps. etc., will be deleted if it was not backed up.
Press and hold volume down key and power key for a while, your screen should turn on with option to enter recovery, follow the prompts to enter recovery mode and set the device to factory defaults. Check the link below for tutoral on reset. Good luck.
Bu yanıt yardımcı oldu mu?
My phone doesn't have any network
My tablet says that it still needs more charging, even though it doesnt
How am I supposed to hard reset it if my screen is still black
my photos are not saved in sd card they are saved in tablet, i don't want to delete those
i try all of the ways but nothing works please help me
There could be several reasons why your Huawei tablet is not powering on despite checking the connector and battery:
Son 24 Saat: 12
Son 7 gün: 51
Son 30 gün: 232
Her zaman: 45,304
14 Yorum
where to buy an extra board power ic ?
Jozhua Linda tarafından
it's can't read the puce
fatima tarafından
My Huawei t7 cannot power on. I have also press the reset button (volume up+power), but it's not responding. Can I solve it with PC?
Saleh Akram tarafından
my huawei t3 7 can power on but the screen is blank what should i do?
Samkelo Chief tarafından
It ask me for a code.
Melissa tarafından
9 tane daha yorum göster
