Ana içeriğe geç
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
402 Soru Tümünü görüntüle
Power light turns on, but the speakers pop and it turns off.
So I was letting my 5 yr old brother use the device (foolish, I know, but I'm just too nice a guy for my own sake), and he dropped it on the ground. It immediately shut off and now what's happening is I press the power button, the light goes on, stays for a few seconds like usual, but then the speakers "pop" and the whole thing is off again. I tried opening it up but couldn't find anything I could recognize as out of order, but then again I didn't really go that deep. Does anyone know how to fix this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You should check the ribbon cable connection also may have a bad/broken fuse. You will need to test current of the fuses if the ribbon cables are fully seated.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
How do I check those fuses?
tarafından
How do you check the fuse
tarafından
Yorum Ekle
The same thing is happening to me but one of the cables of the speaker is broken
Puan 0
1 Yorum:
yeah i have the same problem but i spilled pop on it
tarafından
Yorum Ekle
So I actually know what is happening here. A specific cable going from the mother board through the hinge without a light, to the top screen and speakers, is broken. This is caused by this cable being cut like scissors by the hinge. I cant really explain it well, but I know a You-Tuber who can explain it in detail and how to repair it. His link is here: https://www.youtube.com/watch?v=eAVDyIWg...
There is also a part 1 where he takes apart the 3ds, but its not a 3ds xl, so i recommend using the guide to replace the upper screen that ifixit has, but don't replace the screen.
Puan 0
Yorum Ekle
Yanıtını ekle
Ace in the Hole sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 660
