Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
iPhone 6 turns off at 30% ; water damage
I got an iPhone 6 which is damaged by water:
I have changed the battery, charging port and the display.
But I got 3 big problems
Touch ID is not working, restoring is just working in recovery mode but not in dfu mode and the third and biggest problem is, the phone is turning off at 30%, tries to restart immediately but fails. When I plug in the charging cable, the phone starts immediately and charges up to 100%.
But it turns off at 30 % every time.
Is it possible to fix this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
battery is power rail is probably shot. check the components on the battery power rails with a multimeter. clean off board and do ultrasonic cleaning. have bga chip xrays done, if your ocd.
I am working on hacking the touch id pairing, but until I succeed, your touch id is shot forever. only the mighty apple men (and women) can fix it
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Feel for hot spots on the board while charging the phone. Like he said, there is a good chance the battery is damaged. Cleaning the board with a tooth brush and isopropyl is a cheap alternative to an ultrasonic bath. Remove all of the shields if you have a hot air rework station. Any hot spots would indicate a short in the area, look as closely as possible at the components in that area to find and replace any damage.
Puan 0
1 Yorum:
i have cleaned the board already with isopro and ultrasonic.
The battery is also new.
tarafından
Yorum Ekle
Yanıtını ekle
christian sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 111
