What should I do if my battery won't charge?
My battery isn't accepting a charge at all, and the cable is plugged in.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If the device is not charging while the the cable is attached to both a power outlet and the charging port on the device, the battery may be fairly easily replaced by unclipping the old battery from the motherboard and replacing it with a new battery. If this does not solve your problem, you may need to replace the micro-USB port located on the motherboard which requires more work.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 760
Student, being worked on by hardworking students
L Pfaff tarafından
