New screen worked at first and now it wont.
I changed the screen on my wives iphone 6 plus. Routine procedure. New screen appeared to activate and light up fine. Then a blueish tint appeared over the batter icon and the screen became hot. I shut it off to dbl check connections and now it will not tirn on at all. Tried a new screen and that wont light up or work. Any help would be appreciated
Bu iyi bir soru mu?
Was battery unplugged when you unplugged / plugged screen cables?
Ben tarafından
No. Battery was not unplugged, just phone was shut off
steve tarafından
With the battery cable plugged in it could have shorted the screen and then the board as well. You may want to attempt to replace the battery and if that does not work the board may have been shorted and you should take the phone to a reputable micro-soldering repair shop.
Mike Kaditus tarafından
I suspect the backlight filter may have blown.
Try connecting the phone to a computer and see if iTunes detects it.
If it does check the screen if it displays an image with no backlight, you can use a flashlight to see if there is display on the screen but it is a bit tricky to see as you may need to look at it at an angle and/or put the flashlight on an angle.
Like Mike said, might need to take it to a shop that does micro-soldering and fixes backlight issues.
Ben tarafından
