Ana içeriğe geç
How short circuit protection works?
Hello everyone, in official ASUS Vivobook X556UQ commercial declared, that this device has a short circuit protection. Can you tell me how it works? In what cases battery is being shut off? Will it shut of if I pour water on laptop? Please find a link attached. Thank you
https://www.asus.com/Notebooks/ASUS-Vivo...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
The battery and charger inputs have fuses. A short circuit will blow the fuse. Also, laptops and notebooks run on lithium batteries and have complex monitoring of power consumption from the battery. This is easily achieved with a shunt resistor (a low value series resistor that is used to measure current) which is hooked into the battery management circuit.
It is pure marketing hype to include a mention of short circuit protection. Short circuit protection is something that most electronic devices should have. If it has a lithium battery it SHOULD have short circuit protection because they can put out sufficient current to cause fires.
The battery will be shut of if there is either high current or the battery has dropped down to the cutoff voltage. Lithium batteries are damaged if the votalge drops below a certain level.
If you pour water into the device is won't necessarily shut off the battery because it won't detect an abnormal level of current consumption.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
ignasp789 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,129
