Ana içeriğe geç
Marantz ev sineması AV alıcıları ve eski ses odaklı alıcılar için destek ve onarım bilgileri.
Why won't my amp turn on?
I have a Marantz model 1040 amplifier that wont turn on. I checked all of the fuses, they are good, and when the amp is plugged in, I can get power through one of the outlets that is on the back of the amp. Still doesn't turn on. Not sure where to start.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
kalewenczel I'd start by looking at the power supply for the amp. You will have to disassemble it. Take plenty of pictures and post those with your question. Use this guide for that. It will allow us to see what you see. Check the large capacitors and diodes on the power board. Attached image shows the location of the parts
Resim
and here is the schematic for it
Resim
You do not just want to check the fuses for continuity but check to see if you have power on them as well. Let us know what you find.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Check the power switch on the receiver. Make sure is is getting power to it and not broken inside. This units are notorious for this.
Puan 0
Yorum Ekle
Yanıtını ekle
kalewenczel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 8,854
