Ana içeriğe geç
Repair guides and support for coffee makers by Keurig including the K-Cup systems.
464 Soru Tümünü görüntüle
does not poke coffe pod
can I get my Kurig coffee maker repaired........it doesn't poke the pod for the water to go through the pod......... feels like it might be bent ???
Bu iyi bir soru mu?
Puan 4
7 Comments
@esmills__16 can you post some images of the puncture needle? Use this guide Adding images to an existing question for that. What exact model is your Keurig?
tarafından
no photos but he took it apart and back together again....and it is working.....thank you so much for your help........Ellen.
tarafından
I am new to this site, but i am trying to figure out why the exit puncture needle is not poking a hole through the bottom of my coffee pod that i put in?
tarafından
I am having the same problem!
tarafından
I'm having the same problem. So I improvised and punctured a whole at the bottom and it works.
tarafından
2 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
@esmills__16 if it is truly bend you can replace the needle assembly (depending on your model). Every now and then you can find the parts at places like this. On this guide in step 9 you see two small Philips head screws on the left hand side (above and below the water inlet). Those hold the needle assembly to the top part. Remove those to remove the assembly. Again, take lots of pictures and post those with your question by using this guide.
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Keurig Coffee Maker Görseli
Kılavuz
How to open and clean Keurig Coffee Maker
Zorluk:
Orta
30 minutes - 1 hour
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
My experience is some pods have a harder plastic type covering rather than a thinner foil type.
tarafından
Yorum Ekle
It looks like the bottom needle that punctures the bottom of the coffee pods has come out of the assemble. Can I put it back in or do I need to get a whole assemble replacement?
Puan 1
Yorum Ekle
I took the bottom assembly out, but I didn't see a needle. It no longer makes a hole at the bottom. What can I do?
Puan 1
Yorum Ekle
Yanıtını ekle
Ellen Sergas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 29
Son 30 gün: 148
Her zaman: 25,065
