Power Light Blinks On And Off (Don't Come On)
Magnavox HDTV Model 50ME313V 7 television doesn't come on. (power light blinks on and off)
Bu iyi bir soru mu?
Bu iyi bir soru mu?
if the lights are blinking in a pattern, this may indicate a trouble code. depending on the age of the set, i would suggest logging onto the mfr. website and down load a service manual. the site may a have a forum where your problem is discussed. also check out you tube for your problem; i'm sure you are not the first person to have this problem.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 533
Hi,
Is there a pattern to the blinks or are they continuous, e.g. 2 blinks - pause - 2 blinks pause or something similar etc?
jayeff tarafından
Have you checked the power supply? Normally a blinking power led suggests you have some bad capacitors.
Felix tarafından
