Ana içeriğe geç
ZTE ZMax Pro; siyah rengi, arka kısmındaki parmak izi okuyucusu ve arka kapağının altında bulunan Z981 model adıyla tanımlanabilir.
Factory Phone app keeping crashing won't open!
Every time I open the phone app it keeps crashing and saying "Unfortunately the phone app has stopped working." I shut off my phone and it worked once but that was it. Keeps saying the same thing afterwards.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
3 Yorum
My contacts and messaging won't stay open
tarafından
My gallery and camera apps do this almost all of the time
tarafından
Same my messages and YouTube won't open
tarafından
Yorum Ekle
8 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Find phone app clear cache then erase data and press OK..Try to make call now, it should work just fine.
Hope this works for all good day!!
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
Worked for me! Thanks! :)
tarafından
This worked on my mother's phone! Thank you! :)
tarafından
Yorum Ekle
I'm a sales representative at MetroPCS. We had a customer with this problem and simply had to check for a system update in the settings under about phone. We updated the system to the latest version and it seemed to work fine!
Puan 2
2 Yorum:
Working so far...
tarafından
Ok I just bought my ZTE Blade Z and only had it 2 days and it had a complete system crash and what has not crashed the silly thing says it is blocked and you go around the block and the system directory is wrong path on a new phone out of the box from metro PCS and think I maybe lucky enough to have just given up a few "BIG" dollars and the silly thing wants to crash and I have not even rebooted it from the factory reset page AGAIN
tarafından
Yorum Ekle
It may help if you tell me which smartphone you have but try this solution, go to settings then application manager then go to All apps tab ans search for those two apps, "phone and Contacts" just before continuing backup your contacts to your SIM card or SD card if they're stored in the phone storage. enter the app setting and Force close it then press Clean data the cache will be automatically cleaned in the processes. then reboot the phone for the apps to auto start again.
if you still encounter the issue you may need to reset your phone and this means deleting everything in the phone (only apps and settings your storage will remain untouched, well if you do it the right way). and if this doesn't work also, i guess the only solution would be to install a new firmware/flash and that depends on what smartphone you have.
Puan 0
1 Yorum:
I would check for a system update before using this method to avoid losing all of your data and/or applications.
tarafından
Yorum Ekle
This happened when i had zte zmax pro brand new. I installed all my desired app and factory phone app stopped working. I tried the clear data thingy on the phone and contact and worked after reboot but it happened again after 1 testcall. Did it again and same issue occured. So I end up doing the factory reset and so far, after 3weeks of fixing it, i never encountered it again.
Puan 0
Yorum Ekle
Why isn't my phone working?
Puan 0
Yorum Ekle
i had this problem and I reset the phone to factory settings....It has worked beautifully after that ...Save all data...Apps remain, but passwords need to be reentered
Puan 0
Yorum Ekle
Go to settings.
Go to apps.
Select Stock Android.
Go to permissions,
Disable all three.
Then go to notifications,
Disable notifications and
Disable peeking.
Works like a charm.
Stock Android can't be disabled,
But this satisfies the user experience, also because all those settings are disabled, the app itself is practically ignored not taking up necessary phone utilization processes.
Puan 0
Yorum Ekle
My Coolpad keeps saying phone stopped I tried everything up above and nothing worked it still says the same thing like last time somebody please help me.
Puan 0
Yorum Ekle
Yanıtını ekle
Jen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 20,667
