Ana içeriğe geç
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
369 Soru Tümünü görüntüle
N3DSXL only turns on with blue light then shuts off.
Hey all. I am repairing a N3DSXL and replaced the bottom screen with a replacement from ebay. Unfortunately, the 3DS won't turn on when I try to boot it up. It turns on with the blue power light and the bottom screen can't really turn on and a slight 'pop' is heard.
Here is the screen I replaced it with:
http://m.ebay.com/itm/Replacement-Lower-...
I did take it apart several times more to check for loose ribbon cables but, no dice. Any ideas what it might be? The screen seems to differ also in that it has one less gray-ish connector on the top. But, that's just what the replacements seem to look like. Everything is connected properly and I didn't forget to connect anything. Could I have connected one of the ribbon cables found underneath the motherboard incorrectly?
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi Janis,
I've answered a very similar problem with a 3DS XL that would shutdown as the user closed the lid. This is the same exact problem as you've indicated here with the "popping" sound. There is a fault in one (or all) of the ribbons in the hinge of the device.
See my 2nd answer here: 3DS XL shuts off sometimes when closing screen, to solve this problem and get your device running again.
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Janis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 8,400
