Ana içeriğe geç
Hands-free voice-activated device by Amazon powered by Alexa Voice Service. Model S04WQR.
14 Soru Tümünü görüntüle
Alexa can't set alarm for me. Says is a problem when I ask.
In past could set alarm by asking Alexa to set alarm for a time specific. Now she says alarm set...then few seconds later say problem setting same. Help, thanks and Happy New Year.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
1 Yorum
I have 8 echo dots covering 3 generations...suddenly today only the first gen dot is able to understand what a timer is. The others reply with..."Hmmm, I'm not sure". Oddly, when I ask them how to set a timer they respond with, "say something like, Set a timer for 5 minutes", but when I do, I still get, "Hmmm, I didn't understand" or" I don't know that one".
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had the same issue. My Echo Dot was connected to wifi and would interact and tell me the temperature.
Every time I tried to set an alarm it would take the command, and then about 5 seconds later respond and say it had a problem setting the alarm.
After reading this post I decided to try power cycling it. That seems to have worked - it took the command. It also is showing up in my iPad Alexa app.
Problem solved.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
There is a problem connecting to the amazon alexa service. You should check if it is connected to wifi, and if so, if the wifi is connected to the internet.
Puan 1
Yorum Ekle
Sometimes Alexa enabled device like mobile app does not support alarms or timers.
Puan 0
Yorum Ekle
Open the Alexa app. On the side menu, go to reminders and alarms, click the alarm tab and push the button to the on position
Puan 0
Yorum Ekle
Just go to settings and choose factory reset option.
Follow the instructions and your problem will be solved…
Puan 0
Yorum Ekle
Yanıtını ekle
Larry Hirsch sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 100
Her zaman: 22,284
