Ring/Silent Switch won't stay clicked up
Just started happening out of nowhere. My ring/silent switch wont stay clicked up. It presses up and just springs back down. I'm out of warranty and have no issues taking apart my phone. How does one repair the switch? Any help will be greatly appreciated!
Bu iyi bir soru mu?
17 Yorum
Start by opening up the phone and see if some type of debris is causing this issue. If not then there are a couple different ways to fix/replace the switch.
Austin Harris tarafından
Thanks for the response! I opened my phone and nothing seems to be interfering with the switch. How do I go about fixing/replacing it?
dailyshane1234 tarafından
Without opening the body, I took a needle and cleaned around the switch especially the corners blowing air simultaneously . There were tiny specs of dirt and grease around the switch. Immediately after cleaning the switch stared working properly. It would not stay down earlier. You will not see the dirt accumulated from outside, but if you take a pointed object and run it around the switch especially in the corners you will see the dirt come out. Good luck this was a very easy fix.
Gaurav Garg tarafından
Thanks Guarav, this saved me too!
Jennifer W tarafından
Thanks Gaurav it works
Ajith kumar k tarafından
12 tane daha yorum göster
