Ana içeriğe geç
Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
54 Soru Tümünü görüntüle
Permanent overheated TC last 4 month
Hi!
My TC is permanent overheated las 4 months. I tried to clean it with service engineer, but overheat issue appears still as usual. Cooler works very loud, but engineer said it's ok.
I heard it is a bug of most TC devices and some people knows a tricks how fix it.
Can you give me advice what to do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I know of no tricks here ;-{ Most of the time the fan is clogged.
You may need a new fan if its always racing as that might be a bad tachometer. Did you damage the fan connector or cable during repair? As that too will cause it to race as the tach is not communicating to the thermal management circuit.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I had this problem, solved it by a complete tear down of the time capsule, and clean the fan very thoroughly. Canned Air, WD 40 on the blades. Then removed the sticker on the underside of the fan and added a couple of drops of 123 oil.
It has been working good so far since the cleaning. But it has only been 24 hours.
Puan 2
2 Comments:
Both the WD40 & 123 Oil you used will over time collect dust and gum up the fan again. The better solution is to just replace the fan and not use oil of any sort.
tarafından
hi there, i am having permanent orange light even after replaced new fan, any other suggestion that i can try to fix this issue?
tarafından
Yorum Ekle
Fan needs to be replaced if the RPM are not showing.. and the temp sensor might also be damaged.
I just fixed one.
https://sites.google.com/site/lapastenag...
Puan 0
Yorum Ekle
Yanıtını ekle
sergio.chaplygin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 2,653
