Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
888 Soru Tümünü görüntüle
Wont connect to itunes
The iPod charges sort of ok. I will plug in the charger and after like 30s it will start charging. If i plug it into my computer itunes doesnt see it at all. Should I replace the logic board?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
LCD iPhone Ekran Tamir Kit'leri
Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
Shop Kits
Onarım maliyetlerini düşürün, kaliteyi değil.
Shop Kits
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I swapped the mobo out for an 820-1975-A mobo. Granted the hdd was 60gb, it still worked and all 60gb were seen by the iPod. Connects to itunes and charges too
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
No, sound like a battery
iPod 5th Generation (Video) Battery Replacement
https://www.google.com/search?q=ipod+5th...
Puan 1
Yorumlar:
I just replaced the battery with a new one. It charges fine, just it wont connect to itunes
tarafından
What cable are you using? Is it an aftermarket one?
tarafından
Nope regular apple one. Its weird because the cable will charge and connect other ipods to itunes, but it only charges this one. It will not connect to itunes
tarafından
And the charging port is soldered to the logic board. It would be cheaper to try the charging port, but not easier than changing the logic board
tarafından
I have some spare logic boards. Should I try replacing it with a 820-1763-A or an 820-1763 board?
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Vlad Nikolayev sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 54
