Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, iPhone X, iPhone XS ve iPhone XS Max orijinal ürünleri için nasıl-yapılır kılavuzları ve parça değişim kılavuzlarının tamamı.
36601 Soru Tümünü görüntüle
Error On iPhone 5s Activation
My Ip5s just had a "searching problem" on network, i tried to reset it and failed to activate it, a messege appeared "...COULD NOT BE ACTIVATED BECAUSE ACTIVATION SERVER IS TEMPORARY UNAVAILABLE.." I tried to connect it to itunes but it displays "iphone" all the time. Tried to reboot it by holding Home and Power button but still failed to display itunes plug. Please help me fix my problem, I did everything i know but still dont work. Anyone please help me, you're answers are highly appreciated. Thank you very much.
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
This happened while you were in the middle of using your phone? It was already on, and everything was normal?
tarafından
i phone 5s is showing “iPhone is disabled connect with the itune”
Please explain steps to reset the iphone 5s.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Reset it again.
Make sure you SIM is in, doesn't matter if the SIM is active. Connect to wifi, then connect to your PC and iTunes. No idea why but some phones need the trifecta of SIM, wifi and iTunes to activate.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
DFU restore - check flex cables - try new charging port & battery & screen - clean LB in ultrasonic if not Probably hardware, which is all but improbable to fix .... is it a customers phone ?
Puan -1
Yorum Ekle
Yanıtını ekle
renee anne bartolabac sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 194
