Paper not leaving tray
Paper tray is full but printer indicates that it needs paper. It won't print.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
First I recommend checking to make sure the firmware is up to date.
Next try a hard reboot I.e. Unplugging the power cable for 30 seconds.
Next if you are using another software to print try using the hp photo creation software, you might be getting an error for that reason
also make sure you select the right type of photo paper, there are a lot of choices and it makes a big difference .
also remove the regular paper from the bottom tray,only use the photo paper when printing photos. hope this helps you
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 283
