Ana içeriğe geç
iPhone 6s plus wont turn on
alright i have this iphone 6s plus its my brothers phone and he asked me if i could replace the battery for him cause its dying to fast (cause he is always on it)so i said if you buy it sure and so we ordered a battery from scanditech on amazon they have been good so far with my past orders and i changed the battery and it worked fine then the next day hasnt even been 24 hours yet and he is saying it died at 36 percent i doubt it did and hes the kind of guy that will find anything wrong with something even if its not broken he will complain so i said whatever and id put in the old one so i then saw the old battery had a hole in it or the black cover whatever and so i guessed it was broken i put it in wouldnt fire up so i put the new one back in and put it all together and it wouldnt turn on i left it on the charger for a long time i held the power button held the power and home power and volume did everything and nothing so i now took the phone apart and i checked all the connectors they were all in i took them off to see if they are damaged and they all look great and before this battery changed the phone has never been opened i made sure everything else is connected and everything is fine and wondering if anyone had any ideas the screen works fine the buttons work and no the phone isnt on it doesnt vibrate sorry its so long and for the lack of punctuation
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It sounds to me like you have a defective battery. Buy a new one (or have scanditech replace it under warranty). There are lot's of poor quality batteries on the market.
Was the phone charging the original battery prior to you replacing it? If not, then it may be a problem with the charging circuit (U2/Tristar) but the first thing to do is to use a known-good battery. iFixit batteries are good quality.
iPhone 6s Plus Battery Görseli
Ürün
$29.99
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
1. Verify that the Sleep/Wake button functions. If it does not function, inspect it for signs of damage. If the button is damaged or is not functioning when pressed, seek service.
2. Check if a Liquid Contact Indicator (LCI) is activated or there are signs of corrosion. Learn about LCIs and corrosion.
3. Connect the iPhone to the iPhone's USB power adapter and let it charge for at least ten minutes.
4. After at least 30 minutes, if:
- The home screen appears: The iPhone should be working. Update to the latest version of iOS if necessary. Continue charging it until it is completely charged and you see this battery icon in the upper-right corner of the screen . Then unplug the phone from power. If it immediately turns off, seek service.
- The low-battery image appears, even after the phone has charged for at least 20 minutes: See "iPhone displays the low-battery image and is unresponsive" symptom in this article.
- Something other than the Home screen or Low Battery image appears, continue with this article for further troubleshooting steps.
5. If the iPhone did not turn on, reset it while connected to the iPhone USB power adapter.
- If the display turns on, go to step 4.
- If the display remains black, go to next step.
6. Connect the iPhone to a computer and open iTunes. If iTunes recognizes the iPhone and indicates that it is in recovery mode, attempt to restore the iPhone. If the iPhone doesn't appear in iTunes or if you have difficulties in restoring the iPhone, see this article for further assistance.
7. If restoring the iPhone resolved the issue, go to step 4. If restoring the iPhone did not solve the issue, seek service.
Puan 1
Yorumlar:
This sounds like it was copied and pasted from Apple.
tarafından
Its one of the students on here. I like the idea of what they are doing but posts like this just clutter things up and confuse people.
tarafından
@raichel121 - Its best to create a link to someone's text Vs copying it and posting as your work. If you do post some text from a document then put double quotes around it and also link the source document.
As an example I would write my response:
Review this Apple T/N: If your iPhone, iPad, or iPod touch won‘t turn on. Jump down to "If your device turns on but gets stuck during start up" As I think that is your problem.
To make the link [ -- URL -- | -- the text -- ]
Remember this is just an example ;-}
tarafından
My phone was stuck in dead battery mode for a long time. If you connect it to your mac or pc via the usb cable and reboot a couple of times you will see the Apple logo appear.
tarafından
Yorum Ekle
Yanıtını ekle
Michael sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 8,644
