Ana içeriğe geç
Released in October of 2014. This model, SM-G530H/DV Samsung Galaxy Grand Prime, comes in a White, Gray, or Gold casing.
148 Soru Tümünü görüntüle
When my phone won't charge.
Hello I need your answer please.
My phone won't charge. Every time I put the charger unto it, at first it will charge then after maybe 1 minute it wont charge again. I used every charger at home but still it won't charge. I removed the battery and restart but still nothing happened. Is it because of the battery or the phone itself?
Please respect my question and I am looking forward for your suggestions thank you :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
By not charging after 1 minute do you mean that it doesn't charge as in the battery percentage doesn't go up? Or do you mean that it's not detecting that a charger is even in the USB port? Also, if you could, try plugging it in and wiggling the USB connector around inside the port a little bit, if it connects and disconnects every time you move it around then your port is probably damaged from being used so many time, it's just from usage. Take a look inside if you can and see if it's messed up. If that's the case then you'll need to take it to a repair place to have it fixed unless you know how to solder because on this model the USB port is soldered onto the main board. If it isn't damaged and wiggling it around doesn't do anything then I would try a factory reset and if that doesn't work I would try flashing it, if that fails then I would send it in for a repair because a chip might need to be re-soldered.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
i bought a new battery put it in my phone on charge and it doesnt show that its charging. why?
Puan 0
Yorum Ekle
i tried everything best bet is to clean out the port ,or take something small and lift up the tab in side the charger port gently to make sure it is touching the metal all the way
Puan 0
Yorum Ekle
Yanıtını ekle
Jezreel Obedencio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 2,582
