Ana içeriğe geç
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
It stays on a white screen after the gameboy advance screen appears
My gameboy usually calls but does not enter the game.
help me
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Have you tried cleaning out the game or cartridge slot with some rubbing alcohol? If not, get a cotton swab, soak it in rubbing alcohol and then clean out the pins of the game. Use a good amount on the game then insert it into game slot a few times to clean off the internal pins.
You can also clean off the SP pins with some 600+ wet/dry sand paper and gentle sand them a bit. When you've finished sanding, make sure to clean with rubbing alcohol to remove any dust/particles. This will also remove any difficult grim on them.
Try this out and report back if either of those 2 suggestions work.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
My friend, thank you for this post. In Jesus name after seeking help with him because i have been trying to fix my sapphire for almost 2 hours earlier, I searched again for different methods on how to fix the same kind of issue and it directed me to this post. I tried it and it worked. thank you so much!
tarafından
this worked for me too!! thank you
tarafından
Do you have to remove any plastic in order to sand the pins?
tarafından
Yorum Ekle
Might need to provide additional information here. Does this happen with GBA games or GB(GBC) games only? A specific game or all types across the board? I know the issue can span from dirty pins and cold solder joints on either system mobo or game cart pcb. Console mobo being the harder repair as you have to trace back and find where the issue is. Currently working on this on a unit myself and occurs only with GBA carts. Calls for the info after Nintendo Logo and stuck on the white screen, doesn't boot the game (which works on plenty of other consoles).
Puan 0
Yorum Ekle
Yanıtını ekle
cezar.maekawa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 102
Her zaman: 16,976
