Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
464 Soru Tümünü görüntüle
iPad stuck in recovery mode after LCD replacement
So after replacing the LCD and power/volume buttons on my iPad 4 my iPad will bootup but default to recovery mode. I have tried all the obvious solutions to fix the problem like the iTunes update route and power button/home button combination route with no success. The screen appears as normal and looks completely fine. I am wondering if anyone has had any similar issues. Could it be a screw I put in the wrong spot, or could I have damaged a small part on the board that I can get fixed? Either way I am hoping for a solution and I greatly appreciate any help. Thank you!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
Some context here: i do not want to restore it because it has too many priceless memories. this is not a recent problem, i did this repair 6 months ago but i am just now losing patience and searching for help. Please!!
tarafından
Have you tried doing a iTunes restore? Sometimes the iPad just needs to be restored if the update fails with error code -26 for example.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
You mentioned you replaced the power button and volume buttons. It could be that cable is being depressed and something is causing the device to enter recovery mode. Its a pain, but if you can get back into the device and re-seat those cable connections on the logic board that could solve the issue, verify the buttons click freely and aren't spongy at all before trying to replace them again.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Donny Cara sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 122
