Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
4051 Soru Tümünü görüntüle
Ghost clicks after 3 minutes of usage
On my iPhone 5s, to works perfect for first 3/4 minutes of usage.
Then it seddeny starts doing ghost clicks and non responsive.
(I also see some vertical lines on display)
Then I lock the device (turn off display), wait for 2 min Aprox. Unlock again and it works perfectly for next 2/3 minutes.
As the cycle goes on.
Is this a genuine bug or specially granted to me?
How can I fx it?
Already tried
Reset
Restore
Reboots
Re-fixing display and touch strips.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
It more than likely sounds you received a faulty screen, or you may have damaged it installing it.
Try another screen and see if that resolves your issue, as there is a lot of garbage being sold on the likes of eBay etc. :-)
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I recently had a similar issue on my iPhone 5. The glass had separated some from the LCD and dust had gotten in there. It would open apps, type gibberish in text messages, etc. Replacing the display assembly fixed it.
iPhone 5s Screen Replacement
Puan 1
Yorum Ekle
Yanıtını ekle
Mehran sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 50
