Ana içeriğe geç
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
212 Soru Tümünü görüntüle
How could I replace the key "Enter" on my keyboard?
Hello,
I want to replace a key on my keyboard, there is something behind and i don't know how to do this, it's possible ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
See if a vacuum cleaner can get it out, if that doesn't work try compressed air.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
Hold off on the vacuum! It's not a safe way as it can create a static discharge which could damage things here.
A can of can'ed air might be able to dislodge whats stuck. Here we want to blow near the area no on top of what you suspect is stuck.
Think how blowing smack in the middle of a piece of paper will hold the paper down not move it, now if you blow at the side it moves. This is the effect you want here.
tarafından
apple recommends compressed air.
tarafından
Yorum Ekle
It is possible to remove the key cap from the keyboard with one of the thin plastic picks. Start at the top edge and gently pry the top two corners up off the board. Should be able to clean it out from there.
Puan 0
Yorum Ekle
Yanıtını ekle
Julien Berjon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 672
