iMac Freezing During Re-installation of OS X
iMAC 8. 1 Early 2008
My iMAC 8.1 had started freezing up. I was running Leopard 10.5, ordered and installed Snow Leopard 10.6. Then proceeded to do the additional updates - after each update the machine would freeze at the end of the update. Would have to reboot. Once the machine was up and running , I would check what was the version of the OS - and it would show that the update was successful.
After the updates the machine would still freeze and would have to reboot. I upgraded the memory to 4GB and replaced the harddrive with a 1TB SATA drive. I used the Snow Leopard disk and successfully installed the OS. But, during the account creation process the machine still freezes.
What other hardware issue do I need to investigate?
Bu iyi bir soru mu?
8 Yorum
Which is your system? Review this list: iMac8,1 Please tell us which.
Dan tarafından
Please tell us the make and model of HD you put in.
Dan tarafından
1. Yes the machine was freezing prior to the install of the new harddrive.
2. Upgraded memory to 4GB first - still was freezing
2. Machine is iMAC 8.1 MB325LL
3. Installed a new Seagate 1TB 7200 rpm SATA harddrive
4. It went thru the partioning process fine
Thanks in advance
Dustin Brock tarafından
OK, I corrected your model info so you can click on the system to the right to get to the guides.
Here is your systems specs: iMac 24" 2.8 GHz Core 2 Duo (Early 2008)
Dan tarafından
Seagate make many different drives can you give us the exact model. Take a picture of the drives box or the drives labels if you're not sure and paste it here in a fresh answer so we can figure things out.
Dan tarafından
3 tane daha yorum göster
