Why won't my phone charge
The phone seems to work but it won't charge.
Any suggestions
Bu iyi bir soru mu?
Any suggestions
Bu iyi bir soru mu?
@flumixed , Lesley, The battery, cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=OsHHpADN...
Bu yanıt yardımcı oldu mu?
Thank you so much for your detailed answer.I will let you know how I go.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 72
