Can't open Asus AIO for change HDD
Hello everyone,
I have an AIO ASUS ET2230INT and when buying an SSD and arranging to change it I find that it does not have any screws, nor see how to open it.
I leave two images of my computer.
http://www.asus.com/media/global/product...
http://www.asus.com/websites/global/prod...
There are models similar to this that in the corners have screws to be able to open, but this one does not have.
I found these 3 screws, but removing them I still can not find a way to open it.
http://i68.tinypic.com/24e8ghs.jpg
The cover you see is to change the ram, I have seen in the manual and only indicates how to change the ram, nothing to open it.
Does anyone know if it can be opened and how?
Thank you.
_______________
Hola a todos,
Tengo un AIO ASUS ET2230INT y al comprar un SSD y disponerme a cambiarlo me encuentro con que no tiene ningún tornillo, ni veo la forma de poder abrirlo.
Dejo dos imágenes de mi ordenador.
https://www.asus.com/media/global/produc...
https://www.asus.com/websites/global/pro...
Hay modelos parecidos a este que en las esquinas tienen tornillo para poderlo abrir, pero este no tiene.
He encontrado estos 3 tornillos, pero quitándolos sigo sin encontrar la manera de abrirlo.
La tapa que se ve es para cambiar la ram, he visto en el manual y solo indica como cambiar la ram, nada de como abrirlo.
¿Alguien sabe si se puede abrir y como?
Gracias.
Bu iyi bir soru mu?
