Ana içeriğe geç
The Ford Expedition is a full-size SUV assembled by the American automaker Ford Motor Company. Introduced as the four-door successor of the two-door Ford Bronco, the Expedition has remained in production since the 1997 model year; it is currently in its third model generation.
77 Soru Tümünü görüntüle
Why are my Rear Brake lights not working
We checked the fuses and they seem fine. Two years ago we had a huge problem with the wiring harness, it would loosen it's connection from our dirt road and the truck would just shut off.
Bu iyi bir soru mu?
Puan 2
2 Yorum
I'M HAVING a similar but weirder problem - in my ford econoline 350 1989 - the rear break right light doesnt work but ONLY when the headlights are on - the turn signals work perfect - its not the bulb - break lights work when headlights are not on - but as soon as they are on there is no power to the back right break light only?? please help
tarafından
Mark, I had 3 different 89 econolines, all with that issue. its a weak ground. what you need to do is find which wire is the ground wire coming from the light, and splice an additional wire onto it, and attach the other end of the new wire to the body or frame.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
nancy , Do you have rear signal lights? If bulbs, bulb sockets, fuses and brake light switch all appear to be good the fault is probably the turn signal switch. Also there is a trailer light harness on the vehicle check at that connection or actually remove the trailer light harness as some have a built in converter that can cause weird issues also. Links below may have some useful info. for you as well. Good luck.
https://www.youtube.com/watch?v=4bSB7LRS...
http://www.explorerforum.com/forums/inde...
https://www.2carpros.com/articles/brake-...
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Assuming you have already replaced the bulbs, there is a switch that the brake pedal touches when depressed that activates the lights. I've seen this switch knocked out of place before or even broken.
Here are two links. The first, the guy shows the location and basic overview of the brake switch in a 2004 Expedition. The second, shows an actual replacement for an 2004-2008 F-150.
https://m.youtube.com/watch?v=upj3LnrJd0...
https://m.youtube.com/watch?v=ZfNk947lqY...
Puan 1
Yorum Ekle
Check the wiring at the multifunction switch in the steering column. The molded plastic connector is vulnerable to cracking & allowing the individual wires to become disconnected. Fixed mine...
Puan 1
1 Yorum:
The multi-function switch was the problem disassemble the multifunction switch inside all the contacts were corroded green and non-working cleaning the multifunction switch isn't hard and it saves you about a hundred and sixty bucks for a new one
tarafından
Yorum Ekle
Yanıtını ekle
nancy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 37
Son 30 gün: 145
Her zaman: 86,356
