Ana içeriğe geç
The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
62 Soru Tümünü görüntüle
Why can't I print a card sized 4.9 x 9.8" using custom settings
why can't i print a card sized 4.9 x 9.8" using custom settings, i get a response that the printer does not support that size despite printing it on several occasions previously?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
How big an area are you trying to print? You may need to use the next smaller paper size, that should work. The only down side here is the larger margins.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
You should be able to print that size, what may be going on is that the paper width needs to be 4.5" and length set to 9.5", you may have to change orientation from Portrait to Landscape.
Puan 0
Yorum Ekle
Yanıtını ekle
Denise sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 43
