Ana içeriğe geç
The Sharp EL-531X is a scientific calculator produced by Sharp.
4 Soru Tümünü görüntüle
How can I fix it?
MY calculator won't turn off except after being left alone for a long period of time and the buttons aren't responding. Also it only displays 0=. and I've even tried restarting it many times.
Bu iyi bir soru mu?
Puan 2
1 Yorum
The calculator will display 1 no matter with the battery or not.
It stop working.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Try replacing the battery and then resetting the calculator.
The EL-531X uses a LR-44 (or equivalent) battery
Here are two images that show what to do.
Battery Replacement
Reset
(click on images to enlarge for better viewing)
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Hi. After changing battery and resetting, all the buttons still didn't work. Please help.
tarafından
Yorum Ekle
I had the same problem and managed to fix it by removing the battery and unscrewing and removing the back cover. That's it. I reckon that the issue happened because the "=" key connection was stuck, so uncovering the calculator might have "released" the connection. Hope this helps!
Puan 0
Yorum Ekle
Yanıtını ekle
fahimakhan2 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 60
Her zaman: 3,863
