Washer buttons won't stay on
When I press the power button, all lights power on then right back off. I replaced the dispenser PCB assembly, but that did not change anything.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
First unplug it for five minutes to allow it to reset.
That failing take a look at my answer here:
Bu yanıt yardımcı oldu mu?
@kodiakbear ,laurinda59 , unplug the washer for 5 minutes, then plug it back in and listen for a click. If no click possible bad CCU, also could be door lock switch faulty or bad connection, start switch and or timer faulty, washer motor faulty, main control board faulty or shorted. Check the links below for more trouble shooting info. the last link is the service manual that could help big time in diagnosing your issue. Good luck.
https://www.youtube.com/watch?v=YdWuLw15...
http://removeandreplace.com/2015/04/10/w...
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 5,759
1 Yorum
Washer won't stay on. Lights do come on but turns off or just flashes. What could this be???
bm97057 tarafından
