Ana içeriğe geç
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120 Soru Tümünü görüntüle
Samsung galaxy tab 3. Not charging
Tab 3 not overcharged. I have followed videos and advise and have disconnected and reconnected the battery from the board and tried to hold the sequence of different button to get it charging etc.. nothing is happening .... charger clicks in and not loose. Tried many different chargers and sockets and even tried the trickle charge from a pc ... help please
Bu iyi bir soru mu?
Puan 5
2 Yorum
I was planning on buying a new battery, however, following you advice, pling, it's charging again!!! Well done and thank you!!
tarafından
i just put in a new battery
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
@lozc ,Laurac , have you replaced the battery, as it could be faulty. A lot of forums feel a factory reset can fix this type of issue, read and follow the steps in the first link below if you would like to try, all data not backed up will be lost.
Reset did not work, The battery, cable/charger, charge port or charging IC may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty or the charging IC may be bad. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board (2nd link)and the heat generated could cause further damage if not very careful. Good luck.
https://www.androidpit.com/forum/602119/...
https://www.youtube.com/watch?v=0fcqUXtF...
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
My Samsung Galaxy Tab 3 Lite 7.0 has a broken charger port, could I take the charger port out of a Galaxy S3 that I have and put it in my Samsung Galaxy Tab 3 Lite 7.0?
tarafından
Yorum Ekle
En Yararlı Yanıt
read this on this site and it worked for my tab 3
Disconnect charger
Hold power button and volume up button for 30 seconds
Keep holding buttons while plugging in charger
Hold buttons for another 30 secs
Release power button keeping volume button pressed
Tab starts to charge
Puan 10
10 Yorum:
Thank you so, so much, honestly!
I was about to give up and send it to a repairing center when I found your solution, and it worked!
tarafından
GOSH , this happen before and I had to pay for repairs ... happened again , this trick resolved it. thank you kind sir/madam... any idea as to why this does happen to these tabs ?
tarafından
I've tried this, but it shows like it's about to charge then goes blank. Not charging.
tarafından
@gabsizaguirre yay glad it helped!
@adhir i really don't know, only found out that this is a common problem with this model
tarafından
Thankyou - just followed the suggestion of Power/Volume buttons and it sorted my wife’s Tablet out .. cheers.
tarafından
5 tane daha yorum göster
Yorum Ekle
Didnt work. Still says 100% charged tho …and works great while connected to power
Puan 0
Yorum Ekle
Yanıtını ekle
Laurac sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 31
Her zaman: 40,796
