leaking water out bottom of coffee maker
my keurig k40 is leaking water from the bottom
Bu iyi bir soru mu?
Bu iyi bir soru mu?
There are several possible causes.
The easiest to check and fix is that the holding tank is cracked and leaking.
Its also possible that the needle is clogged up with grounds, you can use a paperclip to clean out the needle.
It could also be that something is broken inside the which is difficult to diagnose without taking it entirely apart.
Bu yanıt yardımcı oldu mu?
The bottom needle broke off with the plastic it it modes to.
Is there a replacement part available?
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 4,543
