Computer won't boot up
Push power on button machine starts up power wise and get real quite nothing appears on screen
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi! from a hardware perspective, so many things can cause a monitor to not show an image.
-Start with making sure the Monitors are plugged into both the PC, as well as the Power Bar.
-Try a seperate Display cord. (Your VGA, DVI, HDMI, or DP Cables could be failing)
-Try a different port. (most recent motherboards support both HDMI, as well as DVI,) or if you have a video card installed, be sure to try your on board port.
-Try a new monitor if it does not work
-if this does not function, try putting your windows Disc into the Drive, and see if the PC Will boot to this
-If this does not fix it, then look into disassembling the device, vacuuming out the device and components with an Antistatic bristle head, adding new thermal paste, and reassemble the device.
-If this does not work, try a new Video card. if this doesnt work, likely your motherboard if failing.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 23
Her zaman: 1,447
1 Yorum
is the monitor hooked up?
Cameron tarafından Paylaş
