Ana içeriğe geç
Repair guides and support for LED, LCD, HD and other Vizio TVs.
813 Soru Tümünü görüntüle
No picture, I have sound
Something is loose in my Vizio E5001-B1 TV, past couple days when I would walk by my TV the picture would flicker, today I turned it on, no picture, but I have sound. I tried the flashlight check, I don't see anything inside, black screen. Any help appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorumlar:
No everything looks good..
tarafından
@ucadam again I'd suggest that you post some good images of your boards with your question. That way we can see what you see. Use this guide Adding images to a new question for that
tarafından
Yorum Ekle
9 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It sounds like there is some sort of issue. When you hit the input button on your remote do you see any menu? If you don't, take apart the TV and see if there is anything that looks wrong. It looks like it might be capacitors so if you see any of these cylinders where the tops are bloated or have some weird substance on the top, are bad caps and need to be replaced. If you see these they need to be replaced. If you don't have any experience with soldering, take it to some repair shop near you to have them replace them. If you don't see them, report back to me here and we can figure out other options.
If this helps please hit the helpful button. If this answered your question, please hit the accept answer button!
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
This did not help, I took back off, circuit boards look fine, nothing loose.
tarafından
Doesnt matter if its loose, do you see any bad capacitors
tarafından
tarafından
IF you made sure all your connections are plugged in all the way and youv'e tried all inputs (composite, Cable and HDMI are the main ones you want to worry about) If you checked all those and they all have the same thing going on, try this http://www.computerrepairtips.net/how-to... its a little strange but it can work. If not, the tv seems broken anyways so it really cant hurt. Also, Have you checked both the main and the power boards? Also, have you checked that the display cable is plugged in properly. Once again, if all that checked out, try the link that i put above
tarafından
Which one is the display cable..?
tarafından
9 tane daha yorum göster
Yorum Ekle
Vizio told me to turn the TV off, unplug it, hold in the power button for 30 sec, plug it back in, turn it on... Wahla... It worked...
Puan 0
Yorumlar:
That worked for a couple days.. Now when I power it on the screen flickers blue/black, sometimes clears up...
tarafından
@ucadam check the comments left with your question
tarafından
Yorum Ekle
hey @ucadam did you found aNY FIX FOR TV.. MINE HAS SAME PROBLEM AS URS.. all boards looks fine . but still no picture only sound
Puan 0
Yorum Ekle
Very easy fix, replaced the Mother Board, less than $100 took about 30 min start to finish.
Puan 0
Yorumlar:
Motherboard isn't always it.
tarafından
Ty. This seems to have worked...at least for now.
tarafından
Yorum Ekle
The flashlight trick is difficult-dark room, use the silhouette of the light. Not directly. Has to be from the top of tv screen angled down. Move it around slowly with adjusting the light it's self.
I used my phone's flashlight and had to cup the lighting my hand. Limiting the directability of the light.
Took me a few minutes to finally see it.
You can look through the back vents in a dark room setting with hand goggle's
Puan 0
Yorum Ekle
How do you fix back light on tv vizio
Puan 0
Yorum Ekle
I have a vizio tv no picture just sound put flashlight towards screen seem some shadow ness still no picture how do I fix this
Puan 0
Yorum Ekle
This happened to me. Press the on/off button and hold it for a bit. I did this a few times whenever the tv would lose picture and ow it seems to be working like new again.
Puan 0
Yorumlar:
I did that it’s still no picture
tarafından
Yorum Ekle
The motherboard is probably shot
Puan -2
Yorumlar:
Is that a easy fix.? Will it cost alot.?
tarafından
Yes its a easy fix
tarafından
Austin, this isnt a good answer. And it can be an easy fix but it can cost alot at times.
tarafından
How can I tell if the motherboard/main board is shot..?
tarafından
Yorum Ekle
Yanıtını ekle
Scott Adam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 47
Her zaman: 22,103
