My phones touch is not working
My phones touch is not working, water might have been creeped inside the phone
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
As you know water and electronics and electricity are not a good mix.
The minerals in the water, cause corrosion and the water also provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and will not stop until it has been thoroughly cleaned away.
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to completely dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% or less, can also contain scents and is not as effective. If you do check the label to verify the amount and ingredients
Here is a link that in general describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here is a link to the ifixit repair guide(s) for your phone which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 57
