Why is my disc player won't open?
During my Xbox is power ON, pressing button and joystick Disc Player button to open tray...it won't open..what can i do to fix it without costing me more money...??..thank you
Bu iyi bir soru mu?
Bu iyi bir soru mu?
MS has a tutorial for getting the tray open manually: http://support.xbox.com/en-US/xbox-360/c...
Bu yanıt yardımcı oldu mu?
That is one solution; but if the drive still will not open, it will most likely need to be replaced.
There may a game disk or DVD lodged in the player. My suggestion is to first investigate and attempt all manual options to open or fix the player prior to replacing it. If all options fail, then replacement may be your only option. Here is some helpful information:
There is an emergency eject button that can be found directly under the Xbox 360 logo, but the faceplate must first be removed. See Microsoft's Directions to Manually Eject the Disk Tray.
For another useful link, see iFixit's How to Remove a Stuck Game from an Xbox 360. Either of these links should be most helpful.
If that does not work, this iFixit link to repair the Optical Drive should work. See Repairing Xbox 360 Stuck Optical Drive.
Lastly, when all solutions above have failed, you may most likely need to replace the Optical Drive. It is a bit difficult, but not impossible to do. See iFixit's Xbox 360 Optical Drive Replacement.
Kılavuz
Zorluk:
Kolay
5 minutes
Kılavuz
Zorluk:
Zor
Kılavuz
Zorluk:
Orta
30 minutes - 1 hour
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 602
