Ana içeriğe geç
Model A1046 or A1095 / 1280x854 screen resolution
118 Soru Tümünü görüntüle
Soru Kapandı
Can I install leopard on my PowerBook G4 A1095
I have a powerbook g4 1.5GHz 15in. I was told at an Electronic store that I can't install leopard, I'm stuck with Tiger. Is that true?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
No--You can install Leopard (10.5.8) but not Snow Leopard. (10.6.4) I would recommend maxing my memory first as Leopard requires more than Tiger. For your computer that would be 2 GB and you might consider a larger/faster hard drive as well. Link provided to identify your computer and then select the install guide needed. Good luck--Ralph
PowerBook G4 Aluminum
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Thanks! I actually did max out the memory. I have a 80gb hard drive and 60gb free, so hopefully it should be enough for it to run smooth. Again I appreciate it, I had a feeling this guy didn't know much about macs ..lol
tarafından
Unless you intend to upgrade your applications, you should also do a Google search to determine the compatibility of Leopard w/ older software. Keywords = Powerbook G4, Compatibility with OSX Leopard.
A lot of common 'vintage' software won't work w/ Leopard.
tarafından
Yorum Ekle
Puan 1
Yorum Ekle
why you don't can install leopard in that pc? My pc have 1,5GHz and have mac os x leopard, and it's great!
You only need mac pc or intel processor, 1gb memory, 5gb free space hard drive, dvd.
Update
errm.. rj713, my pc have mac os x snow leopard and have 1,5GHz and it's too slow.. but in mac it's fantastic, that's according the pc
Puan 0
Yorum Ekle
As anecdotal evidence, I have run a 1 GHz PowerBook G4 with OS 10.5 Leopard. However, it was somewhat slow (not too bad, just noticeably laggy at times). This computer had 1 GB of RAM and a 60 GB HD, most of which was empty. I think Leopard "requires" 1 GB, but 2 GB would be nice if you can get it.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 4,319
