Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
How to fix it it dies when I put the kick stand up
motercycl dies when i put kick stand up how do i fex it
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevapvvbh
Filtre ölçütü:
Is this a Kawasaki Vulcan 750? If it dies with the kickstand up while you are attempting to shift into gear, then it is likely an issue with your kickstand switch. The switch will be located near the kickstand, and may be stuck in the closed position. Locate your switch, support your bike on a stand, and see if the switch pops out when you put the kickstand up. If not, then replace it. There are other people who suggest jumping the wires to bypass the switch; but, that overrides a safety feature, which is usually not recommended.
The video below shows a brief overview of the kickstand switch and its function, but they are looking at a different bike. The location of the switch may vary slightly, but will be very near the kickstand.
https://youtu.be/TgrXGv1coGU
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Roger Ferguson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 34
