Can't get into recovery / download mode. "No command"
I've been trying to fix an S5 for a friend's parents, but no luck so far.
The problem
The phone turns on and goes straight into the "No command" screen, which flickers every 2 seconds or so
Things I've tried:
- Tried to boot into recovery or download mode. All key combinations end up in the "No command" screen again
- Tried several key combinations while in the "No command" screen to bring up a menu. Nothing works.
- Tried various batteries / cables to see if that would make a difference
- Tried hooking it up to my pc. Phone is not recognized (I don't even get the usb sound)
- Tried a usb jig, but that does nothing and the phone doesn't start
- Tried draining the phone of all power and charged it again
Any suggestions on how to fix this or where to find an answer would be much appreciated.
Edit: video of the phone in question. https://youtu.be/uHNM-9j4ZmY
Bu iyi bir soru mu?
4 Yorum
Which key combinations, have you tried?
S W tarafından
* power + volume up (in several combinations of holding / pressing
* power + volume down
* power + volume up + volume down
* power + home
* power + home + volume up
* power + home + volume down
* home + volume up
* home + volume down
Isoldael tarafından
I have the same problem. The screen is flashing "No command" and I cannot get the phone into recovery mode. Tried all key combinations, tried draining the battery and nothing works.
AGM A8 phone
Any suggestions?
puppeteer701 tarafından
if you can get adb to recognize the device. then you can issue command adb reboot download or adb reboot bootloader or adb reboot....
declanick tarafından
