Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
iPhone 6 error 56
I have an iphone 6 that was updated thru settings to latest iOS and failed and needed to be restore with iTunes. I did so like 5 times now and it keeps failing with error 56. I've tried new cables, new dock connector, latest iTunes, tied both windows and Mac OS but it keeps giving the error. what causes this and how can I fix it? Thanks
Bu iyi bir soru mu?
Puan 1
Yorumlar:
Hi I have the same problem on iPhone se and i fixit. What i was try to do was remove the battery connector to drain the power from the phone but as i use screwdriver to remove the conector there was sparcle so I thing the phone reset as when i try to turn the phone on it show low battery logo and after i restore the phone and it work.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Asked and answered:
What is (unknown error 56) iPhone 6
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
100% solution
NFC IC REBALL & JOB DONE
100% TESTED
Puan 1
Yorumlar:
hello brother
i have done for your idea
very thanks
but my iphone 6 done for error 56 but wifi not work it's Gaye
tarafından
Yorum Ekle
Yeah from days of research and a @%^$$@$ iPhone that is still stuck, I have concluded that it is either the NFC chip (which was working perfectly fine, I have no idea why it died), or my touch id button (tried original and spare ones, original is cracked and touch id may no longer work, but chip on it is in working condition, or my cables/$@$*!& wiring. Someone please help me before I hang myself. Why are androids so easy to fix and iPhones stubborn @%^$$@$# who can't take the slightest beating from command prompt or terminal? Its always the iTunes $@$* that gets me every time. Anyways I am buying a new iPhone tomorrow with hopes that I can have a working phone, but chraiglsist seller isn't responding and I am getting nervous and sad. &&^&^$^ !&&* I am killing myself.
Puan 1
Yorumlar:
I relate in many ways
tarafından
Yorum Ekle
sometimes error 56 is caused by the power supply of camera on iphone 6.
exchange the both camera(which i dont think it would works) and check the cricket might fix ur problem.
Puan 0
Yorum Ekle
Yanıtını ekle
CAB sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 3,601
