Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
246 Soru Tümünü görüntüle
The clicker wont work?
My Ipod that I bought the clicker on it doesn't seem to work. I set it back to factory settings and now its stuck on where it asks about the language type. And I cant get out of it I cant move the selection up or down so I think its the click but not sure.
Whats the problem?
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
Nintendo Switch Kit'leri
Oyuna geri dönmek için hızlı bir düzeltme
Switch Kit'leri Satın Al
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I would also check your battery. If its gets bloated and distended, it will affect the way the clickwheel behaves. I would pop the iPod open and try to use the clickwheel with the iPod halves separated and see what happens.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Have you to reboot it. Menu + select to reboot it. If nothing else works, check the hold button, make sure it's not in hold. can you get in disk mode (select+play) and/or diagnostic mode by pushing rewind+select? The last time that happened to me on a 4th generation is was the logic board that froze and after I replaced it no more problems. Of course that does not mean that what it is in your case, so you will really have to check each part. The hard drive is also known to give errors like that. Is your ipod recognized by iTunes and/or your computer?
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Just had similar issues with a 4th gen iPod, needed a new click wheel an replaced the HDD cable, now it works :-) who knows it may work for you too.
good luck and let us know how it is going.
Puan 0
Yorum Ekle
Yanıtını ekle
Daniel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,536
