Touch screen problem after replacement
I have changed my screen 8 month ago. Nowadays sometime touch doesn't work and unable to record video.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
It is mostly due to a defective screen. But, if a new screen does not solve it like @refectio said, note that this model is prone to:
- Touch controllers separating from the board due to hard drops or bending of the housing; reballing or replacing the touch controllers is necessary; "reheating" is not.
- The circuit powering up the screen is partially shorting (very common for this model). Replacing the failing components is necessary.
Bu yanıt yardımcı oldu mu?
You could simply have a defective screen. Some replacement screens are fairly low quality and have a limited useful lifespan. It could be a logic board issue (first rule out with a known-good replacement screen) if your case has suffered multiple drops or bending.
Let us know if that is the case.
I changed high quality original screen.Never droped ,bend. But also sometime touch doesn't work when i lock phone and play again then touch will respond
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 81
